Clutch cable slackens when riding.... Any ideas?
My clutch cable slackens off (gets looser) after riding the bike for a while, so I tighten the cable using the adjuster. Often, after a little more riding it goes too tight (almost making the clutch slip). Out on a ride I seem to be fiddling about with the clutch adjustment all the time!
I've changed the clutch cable and the clutch plates - the plates were quite worn......
It's still happening though!!
Does anybody have any ideas what I should check next?
Thanks in advance.
Replace the clutch cable or remove the clutch cable and check if the cable is catching on something
Thanks in advance.
Barnet / KG and possibly other clutches are known to do that.  Go with OEM or Moose (DP) clutch.
Edited by billdirt1
Thanks guys for the responses.
The springs were within tolerance so I didnt replace them. The basket seemed fine, but that's a good thought, I will check again. I'll also check the clutch cable routing.
Will report back with an update......
Thanks again.
