RMZ piston band
is it possible to turn down the stock RMZ shock piston ('14 rmz250) to fit a piston band?
and, after few years of experience, is it worth to swap the x-ring for a piston band?
thank you very much
I use Showa pistons from other Showa shocks, just change the 12mm id centre for 16mm id. Then use a low friction band
using the same shim stacks?
nevertheless I'm searching for a "cheap" conversion.
I haven't the shock right here, so want to be prepared when i get it...
thanks karlace :thumbsup:
What problems are you having with the x ring band
I have no problems, my KX has a piston band :D
my buddy has a brand new rmz and I was thinking of improving his shock. that's why I am asking
if it's worth to swap the x-ring...
I use to change every piston, but once the shock is hot, I don't think the x ring is a problem. Not saying a normal piston band isn't better, just saying once shock is working temperature I think they are fine. Just try to chech sag once the shock is warm aswell
Mxt has a conversion kit.
And you get the low friction band with it.
I don't like the x ring.
Cheap conversion is ktm piston(pds or linkage ) but then it's starting fresh on shim stacks , I did a bleed shim setup on a pds piston
Marcus ever had any issues with wp shock valves cracking and leaving small parts in oil?
I am not that confident on wp valve quality.
Pds or linkage or forks ? But no I never have ??
Linkage shock . I've seen it a couple of times and worries me a bit.
One actually did damaged the shock.
yeah, I read this before. but don't want to test new stacks as the rider isn't unhappy with the shock...
I will take a look on the shock, then decide what to do,
thanks guys :thumbsup:
once its just a freak occurance,
or did it happen twice??
Saw it on 2 different shocks.
One was opened before the other not.
That's worrying and I can't tell what part that is or why it would do that
You can see the crack on the left.
This is how it came out, before I disassembled the valve.
I am glad it not happened to somebody else , even though I came across twice.
Edited by DinoY
