Kibblewhite Valves
Ok long story short can I run the stock cam rockers and timing chain when installing kibblewhite valves on my 03 Honda xr400r? Thanks
Warning!
Do not use kibblewhite valves. Seek a substitute version
Ive had 2 sets of KW valves. 1st set lasted 3000km and had to reshim every 1000km
Replaced the full set to (stupidly) another full set. Got 700km out of them, then today 1 of the exhaust valves snapped and dented the hell out of the inside of the head and the piston face
I just ordered a set of Ferrea's, under advice from others who have experience similar disappointment
Seriously, take my advice on this. They have been the single biggest problem with my bikes rebuild
Warning!
What bike are you talking about because these have been working well in XRs?
Yeah, I saw your thread.  That other guy jumped into the fray as well and it sounds like you're not really sure if it was your fault or the valves.  I don't know what they do on the Suzuki thread, but the XR threads are fairly civilized because the bikes are reliable.  In the last two years, I have only heard praise for kibblewhite valves in XRs.  Some feel they're mandatory.
I went with Ferrara Stainless Steel because of the price point and availability at the time. But I did ask about the Kibblewhite Black Diamond vs them prior and the Kibblewhites got good praise - http://www.thumpertalk.com/topic/906065-ferrea-vs-black-diamond-valves/ - but I also found some older threads where others had had issues with them...
Edited by twr7cx
Yeah, I admit that I don't know if it was my fault or the valves THIS TIME, but I'm sure that I only got 3000km out of my previous set of KW valves. It might just be the case that Suzukis are too rough on them
I was responding with my experience to the title of this thread 'Kibblewhite Valves', in general
DRZs have there own problems.On Xrs the KW valves the first ones they made where bad called White Diamond.That was many years ago like 1997.All the black diamond valves we have used Zero problems BTR
Do you have to shim the valves on the xr or just normal reset for the good ol xr when it has the kw valves
Edited by robboxrrider
We recently did a complete top end and crank on a CRF450R.  Used KW valves because they are known throughout the industry as top of the line.  The bike has run a couple WEBE races and a couple motos along with a bunch of trail riding since the rebuild.  The valves had to be shimmed once.  The rest of the valvetrain is stock Honda.  Can't ask for better performance from a product.
