2014 450 SX-F FE Drifting Left
I noticed when I first brought this bike home and put it on the stand that the front end cannot stay centered and snaps to the left every time. I also noticed this drifting on my first ride and it always had a tendency to pull left, not overwhelmingly noticeably, but enough to bother me. Any ideas what the problem could be and how to fix it? Thanks!
I don't think the stand means anything. But pulling, check the clickers and make sure they are set the same. And the fork the heights are equal.
You could also reseat the front axle.
When the front tire is off the ground on a stand the throttle cables push the bars to the left. Im on my 11th new ktm and every single one of them do that. As far as riding it and it feels like your pulling to the left on top of what Steve above says id also check to make sure your axle blocks are the same distance. You probably already looked but sometimes from the factory the bars are not perfectly centered, make sure even and centered.
