01 cr250 power valve?
Your power vavle is jammed half way open from shows in the picture.
If you had cylinder work done its common theirs insuffient clearance for the valve to close.
The owners manual said it will close after starting but now it's still half way open. What is the best way to get it to close without taking the tops end off?
Its either being restricted by the cylinder bore, or the powervalve vertical shaft that runs down to the case isn't connected properly to the keyed actuator. Thats actually common. You can put the cylinder on and not realise it needs to be lined up and seated first. Either way you taking the cylinder back off or at least popping it up a couple inches to check alignment.
^^^^this
It is very important to ensure the shafts are aligned and set up properly when you slide on the cylinder.
