2014 CRF250R, jumps into gear by itself
Have a 2014 CRF250R that will just jump into gear when at idle or reving up. This happens mostly when in netrual any ideas?
Check your shifter is not loose on the shaft. The vibrations can cause it to jump into gear sometimes.
It sounds like you may have a broken shift drum stopper spring (#17 under the gearshift drum schematic).  Has it always done this or did it recently start?  With the bike not running, does it shift into gear abnormally easy (little resistance)?
If your bike jumps into gear by vibration, you've got something seriously wrong.
It just started this just sits there at idle and somrtimes it just goes into gear.
