Wheels!
Check the tire size and or rim size
The hub's really the important part for fitment.  Wheel size is fairly forgiving (think 17" supermoto wheels on a dirt bike).
Bearing ID's (to fit the spacers), distance between the outside of the bearings which drives the spacer dimensions, which is driven by the inside width of the swing arm.
You could probably get it to fit, but you'd have to design and build some custom spacers.
That's just to get the wheel on the swing arm.  You've also got the sprocket and/or brake disc offsets and diameters to deal with too.
Cheers guys may just get the original crf ones refurbishes as the powder coat is chipped away and the kxf wheels I have are minted and was just a thought. I will just keep the rims as they are the same size.
