Cr125 1996 top end in 2005 lower end
The cooling is more the problem, the 05 Cylinder will be cooled through the case the 96 not.
PV is different but could work.
the case might not match that's the biggest issue.
05 head has 1 water outlet 96 has 2.
96 has cylinder water outlet 05 through the case.
But why you want to do it?
Makes no sense to me, 05 has a 5 speed, 96 has a 6 speed.
If you want 5 speed take a 98 Case that will work.
I have a full 05 engine and a partial 96 engine. Just curious to use the hpp valve. That's all. Thanks.
