YZ250 Case Compatibility
I need a left side crankcase for my 2007 YZ250.
Wondering what years are interchangable?
Also if anyone has a left side case, matching set of cases or a complete bottom end forsale please let me know.
Thanks
That's what I thought. Having trouble finding a used one! 01 and older I could find... Nothing newer.
1999 plus should work.  The only differences between the 99-1 cases that I am aware of is the swing arm bushing pressed into the case.  The 1999-01 use a smaller swing arm bolt than the 02 and newer bikes.  You will have to drill out the 1999-01 bushing slightly to make it work.  I'm running a 2001 left side case in my 2002 YZ250.  Hope that helps.
Edited by SFDRZ400
