2007 CRF450R cylinder specs
First I'd like to appologize if this has been covered.
I just picked up a 2007 CRF450 with a blown motor. the piston became detached and blew out the walls of the cylinder. I have been looking for cheap replacements and the 2002 CRF cylinders are considerably cheaper. Will a 2002 cylinders swap right over to a 2007 engine? if not what years will swap seemlessly with the 2007?
well, according to the numbers, at least 04-08 will be a direct fit.
http://www.partzilla.com/parts/detail/honda/HP-12100-MEN-671.html
but cylinder works specify the same cylinder from 02-08, so the earlier ones might work too, or be made to fit with minor adjustments.
http://www.cylinder-works.com/ProductInfo.aspx?item_id=5385
hopefully someone else can chime in on this.
cheers
