'83 XL600 very weak spark
How it looks with the bike not running and cranking it over might not be a weak spark at all.  The question has to be...how does it run?
patuca
patuca
Once it's running, fine.
But to start it cold, I can kick till I'm blue in the face and I'm lucky to get a sputter out of it.
It used to start in 2 kicks, now it's more like 200 :banghead:
But if a CDI bike runs normally after it's started it's a real good indication the CDI is working fine and some other factor is keeping it from starting.  I would spend some time on the carbs, check the valves, put a new plug in etc.
patuca
I'll bet someone has replaced the stock soft silicone plug cap with a hard black plastic NGK resistor plug cap ???  Mine used to eat these resistor caps.  Mine also used to need the crank pick up changed occasionally.
I went and got another new spark plug and it starts fine now...
I had tried used and a couple of new spark plugs before and just bum luck they were all bad.
