Oil drip.
Just got back from a little road ride and noticed oil dripping from the gear selector area by my left foot. It's on the gear selector and appears to be coming from where it goes into the engine case or just above from a screw behind the chain. Anyone know what's causing this oil drip??
Replace the counter shaft seal and O-ring, this is a common issue. The Suzuki dealer recommended going with a synthetic blend rather than full synthetic as this seems to worsen the problem. When you replace the seal and O-ring slightly bent the 2 tabs on the cover back towards you to put some pressure on the seal. The seal is around $7 and the O-ring $2.
No problem, just sharing what I have learned like many others on this forum. Glad to be able to contribute.
