2002 yz front wheel axel and spacer compatability?
have 2002 yz250 aftermarket front wheel with the spacers that came with it. my forks and tripple clamps are off of a 2007 yzf450.i know the wheel is the same but when i try to use my 2002 front axel there is a gap on the non disc side in between the spacer and the fork. i'm pretty sure that's because the sss forks are wider at the bottom so the axel has to be longer. my question is do i just need a 07 front axel or do i need 07 spacers too?
Look at part numbers. Looks like just the axle. Hub and spacers are the same.
07 YZ450F
02 YZ250
cool thanks, was able to use my 11 450 axel nut until i can get another. also bolted the front brake from 11 to the 07 carrier with no problem, feels kinda spongey on the 07 but i'll see if it gets better after i bleed it
