Rotating pressure screw on front fork
Hi all want to rotate my front fork left hand side arm,
I want to install pressure bleeder rhk once and my screw on the left arm is positioned right under the handle bar i want to rotate it so its on the upside same as the right hand side arm
Photos may help
doesn't matter the orientation of the screw.  Could be in any clock position.  As stated before, loosen clamps, rotate as needed, re-torque clamps to proper specifications......
Make sure you don't move fork tube up or down from where it was.  Even small changes can cause different handling.  Make sure it is same as other side when you are done.
It's better to have the screw on highest position.
Blows less oil.
