Another Harbor Freight Trailer Thread
So I had a kid and it didn't take long to figure out my Ranger wasn't going to cut it for our needs anymore. We knew that going in, but reality set in after a week and I bought this lesbaru...
A moth later I sold the Ranger and was stuck taking the big truck if I went riding. Time to invest in a cheap trailer and a hitch for the car. I had a HF trailer before and it served me fine. This time I went for the 12 inch wheels, though. After finally getting through checkout and home, I had this pile of parts in my garage around noon.
Partially assembled and ready for wheels
I greased up the bearings and got ready to install the hub. Found this little gem; weld splatter on the seal surface of the spindle. I knocked it down with my dremel. There were a couple spots, actually. Something to look out for.
I added my side extensions, ran the wiring, and finished for Saturday.
Edited by ubu
I picked up a sheet of 3/4 inch plywood. I had Home Depot cut it in half because I need it to fold. It doesn't fold nice and flat because of the thickness, but it's close enough.
Now I had to lay out my plans for "wheel chocks". Remember I need it to fold, so mounting chocks and removing them would add more time to a job that is not that fun to begin with. My plan was to cut out sections of the wood where the wheel would drop in. I decided to cut the length between the front 2 crossmembers. The outside slots need to be in far enough so the wheel clears the tongue when it drops in. I went with 16 inches from center, which should cause me to lean the bikes outward 3-5 degress when hauling 2 big bikes. Have yet to prove it out.
Test fit of one of my big bike wheels
Moment of truth, will the mini wheel of my stepson's 100 fit?
Okay. Proceed.
Loaded and ready for the maiden voyage last Sunday.
Trailer pulled well. Bike was stable enough. Pretty much what I thought. The right hand tail/brake/turn light isn't working. It worked when I installed the wiring, but not Sunday. It has power and the bulb is intact. Maybe I damaged something when I dropped the rear half (twice already) Got to remember to tie those off BEFORE standing it up. Anyway, a light is about $10. I might get a set of LEDs, though.
Edited by ubu
Those lights are grounded through the frame. try running a self tapping screw through the light bracket and frame that "paint" is a horrible conductor.
Had the same problem with a HF trailer that i pull behind my Goldwing.
Mike
Edited by mike000198
Wheel wells are a great idea, just too long, lets the wheels drop too deep. About half to two-thirds length would have been better and still very secure. You can always make small holes bigger, hard to go the other direction. Five-eights would be plenty strong, fold much better and lighter. Last suggestion is about three cans of a good clear paint like Krylon or Rustoleum on all the metal to help prevent rust, at least in wet climes. The original paint could use some help. I always paint the plywood on mine before final installation, three coats.
Mike
Yes, I will try that first. Or grind a little off where the bolts go through.
Determining the length of that cut took me a few nights of thought. I wanted to go a little shorter, but also wanted support for the plywood. I thought about running a 2x4 crossmember to take up the space, but in the end it was going to be more of a pain than it was worth. In the end, I just test fit the wheels between the crossmembers, and went with it. Good enough. The bike drops right in and stays there; still easy enough to get out.
I wanted to paint the wood, but ran out of time before the weekend. Ended up putting some water seal on. I don't like it. Still get marks from tires and footwear. I have some gray Rustoleum I think I might use to paint it. I think the water seal works as a prep; the instructions say to let dry 3 days before applying oil based paints. I'll need to get started tonight if I want to use it this weekend, though.
Instead of cutting holes in that nice new plywood, I would've put a rail across the front of the trailer. About 8" to 10" tall would be sufficient.But, all in all that's a great little setup. :thumbsup:
I need it to fold...
Wood painted and reinstalled.
Now both lights don't work. On the car, that is. They work fine on the truck. Looks like I have a ground issue in the brand new car wiring, or the fuse blew in the Curt box...
Looks good to me. I prolly would of used washers on the bolts tho. How you like the crosstrek? MPG? Do you use a ramp to load bike onto trlr?
The Crosstrek is nice. I haven't had a new car in 8 years, so not much to compare it too. Main reason I bought it is that my wife wanted a Subaru. But she hasn't really driven it yet :devil:
It's a car and takes some getting used to coming from a pickup. No gauges except rpm and speedo, everything else is a light The factory stereo sucks! I replaced the head unit and speakers before I even made it to the DMV for registration. Overall, it looks good, has AWD, gets good mileage, and has 4 doors and  a back seat for the kid. The cargo area hold all my gear, too; almost more convenient than my Ranger.
I've only got about 2k miles on the it. There's a break in period of 1000 miles where throttle needs to be varied. I read some forum reports of oil consumption, so break in had me nervous. I drove it moderately hard, acceleration and egine braking, not exceeding 4K rpm. Still got around 30 mpg.
Ramp isn't a necessity. I used a ramp last weekend just for convenience. Mine to load/unload at home, and my buddy's at the staging area. I'll probably be leaving the ramp at home unless a buddy with a fat ass 4T wants to carpool.
That's good. We had a Mazda MPV for ten years to haul the family and gear. Damn thing never got better than 20MPG. 2.5L 170HP V6 from a Ford Contour. :foul: Kids are older now so we just got a civic to replace it four years ago. Luckily still have my truck to haul everybody and gear if necessary (rare). It gets 17MPG.
Your buddy would hafta be a pretty manly dude to carpool somewhere in a Subaru. :D
Understood. Buuuut you could still fold it with a rail if it's done right. I guess it's just me, but cutting holes in a perfectly fine trailer.....idk. Different strokes I guess. That should work well for you.
So lights: I re-attached the ground point in the car with a bolt instead of the tiny screw that came with the kit. Still nothing. Turns out the ground path from front to rear was disrupted because I'm removing 2 bolts to fold the thing and they were just snug. I took some paint of underneath the hinges so it will have a better path through the frame, and made sure those other 2 bolts were tight.
I also checked over the trailer again because there is a pinch point where it folds. I had loom there and wires were still intact, but I didn't like it. I bought a male and female flat 4 connectors and spliced them in so I can disconnect before folding. A little more work before/after use, but it eliminates potential shredded wires in that area.
We learned a long time ago that it's easier to splice in a ground wire when dealing with folding beds or drop tongues. Fortunately my brother is amazing with a soldering iron.
I have an HF trailer myself, what's the deal with the 55mph warning on the wheels? Is that an actual limitation in the wheel/tire, or Chinese for "no drag racing"?
Lawyer thing for people who don't take care of their bearings.
Can you get 3 handle bars across?  I had to offset the bikes on my small trailer... front one forward.
No because I didn't offset the center. I have no plans for more than 2 bikes on this trailer. Even with 2 bikes, I will have to lean them out 3-5 degrees. I could possibly get a 3rd one on backwards if I absolutely have to, but not in my plans. If I have 3 bikes, I'll probably just take the truck. It was built back in the day before 8 foot beds went extinct.
