2009 kx250F dies when i pull clutch in?
2009 kx250f just had new piston and rings and valve shims done around 13 hours ago. last time i rode it everything was fine it was running the best it ever has now its &%$#@!ed again. It will start fine when cold and starts first kick when hot but when i pull the clutch in it will just die instantly, like straight away. it was still doing this after riding for a few hours. Any thoughts? need new valves?
I wouldn't have a clue what it is so please help! Thanks
So if you are in neutral and the bike is idling and you pull in the clutch it dies ?
or is it when you put the bike in gear that it dies ?
sounds like clutch is sticking/out of adjustment. pull off cover and check plates, probably grooves in the basket
both, nuetral or in gear, the bike wont idle. as soon as i pull the clutch in it will die.
So if i am understanding this correctly the bike will not idle when hot, the fix might be as simple as turning the fuel/idle adjustment on the side of your carb, if you turn it clockwise it will increase the idle.
I agree must be a low idle condition
In Neutral the clutch being pulled does not affect the motor.
i doubt its a clutch problem
Then you have an air leak somewhere or the pilot circuit on the carb is blocked check following
Pilot jet and passages
Fuel Screw o ring still in place
Slide plate not in upside down
Slide plate o ring still ok
Air leak on the manifold rubber
Hot start lever sealing
Edited by Shawn250
