Flex Jet Issues
I couldnt get the bike tuned correctly after installing the Flex Jet. Decided to take it out and use original spring, O ring and washer. When I tried to re-install the Flex Jet the tip caught on a lip inside the carb and bent (I wasnt forcing anything). Of course when I tried to straighten this small piece of brass it broke off rendering the $30 part useless. So just be careful if you plan on installing one of these. As a side note I re-installed the original pilot and bike runs like it should.
