Kx450f air fuel screw
Fellas, just put a new top end in my bike with head reworked valve seals and all clearances are good. Timing is also good. Won't start. I can get it to hit for a slit second if I rotate the air fuel screw. Any suggestions??
Fuel screw is for fine adjust of idle mixture only.
Confirm your choke works properly.
Replace the pilot jet with a new one
Confirm the spring/washer/oring are on the fuel screw and thyat the tip of the screw is undamaged.
Was the slide out?
