Front Master Cylinder
Anyone know if the master cylinder for the front brake on the e and s models are interchangeable? They have different part numbers but the only difference I can see is that the S has a hole for a mirror and the e doesn't.
jon Member   Posts: 28 Joined: Mon Jun 18, 2012 7:21 pm
The master cylinders are not the same but will interchange.  As noted above the E has no boss for a mirror,  no brake light switch and a smaller bore.  The smaller bore provides more brake pressure for the same lever pull force.
