Can someone id this showa fork spring?
I have this I know is from a showa and the only marking I find is the little chip at the bottom as you
can see in the picture and I will like to know the spring rate
I think you are correct, because I remember I had some springs from factory connection, may be it is this set they were .46 if those are the ones from Fc :thumbsup:
there are not oem spring .
If its not a progressive rate, drop a metal rod down the center to keep it upright, set a large gym weight on it, measure deflection and calculate the rate. That should get you as close as the typical tolerance of a new spring spec.
