2013 KTM SXF 350 tip over sensor or roll over sensor location
Can someone please post an actual picture of where the tip over/roll over sensor is. I've seen another posting of a parts diagram showing the part but I still can't seem to find it and there are no other postings with pictures, diagrams or explanations of the location that is good enough to actually help me locate this part. I need a real life picture of it in place on the bike so I can use other parts to get a bearing and reference to where this sensor is located. Thanks
it is under the ecu . the ecu (cdi) in on a plastic bracket under the seat and the roll over sensor is on the undersite of this bracket . . so you have to remove the alu subframe or the compleet airboot from the filter cover and the throttle body .
