08ktm xcf 250
When you hit the gas and let off it has a high idle for about 2 seconds
It will not hurt to ride it, but it might hurt you......unless you keep a close hand on the clutch....
That is called hanging idle, and while it is a carb problem, it is not jetting
I will assume you have already correctly adjusted your fuel screw. If not, read the 'how to set you pilot' at the top of this forum.
Otherwise
Replace:
Slide plate seal
Fuel screw oring (better; add an R&D remote fuel screw so you can properly adjust the fuel screw for air density changes)
Hot start plunger: make sure it is not corroded and moving freely: clean/polish/grease it and the cable
Hot start nut: they crack, leaking air into the carb. If cracked, replace with zipty aluminum nut
Header crush washer (most ktms do not have this...)
Muffler packing: replace it (stock KTM's do not have this)
Edited by Kah Ran Nee
