yz 125 rear suspension vs. yzf 250
Is there a difference between a 2004 yz125 rear shock and a yzf250 rear shock? My yz is blown out and looking for a cheap replacement
Im thinking of doing something similiar and from what I've been looking at i think the main difference would be spring rate. That may be it... Maybe some slight valving differences but from what I've seen the spring will be quick a bit stiffer. That's all dependent on rider weight though so maybe it will work for u.
Someone else can correct me if I'm wrong. Physically the 2 shocks are the same and can swap out each other. Internally, valving I think is a little different, possibly different spring rates.
But, if your shock is just blown out, why not just rebuild it?
