Turn Signal issue
Just noticed something this morning. The right front turn signal stays lit (non-flashing) whenever the key is on. When I switch the turn signal to the right the right front turn signal flashes normally as does the right rear. The left turn signals front and back work as expected. I don't know how long it's been doing this. I haven't looked into this yet. Has anyone seen this before?
Thanks,
Larry
Thanks,
Larry
they take a dual filament bulb and both the fronts should stay on with just the key on as they are running/marker lights. If you have one that is not lite then it needs replaced.
  • Like 2
What Gnath said is correct. The light that isn't staying on is the issue.
Doe sit look like this? (sorry, not a CRFL but same idea)
It should look like this:
  • Like 2
