Hello I'm need info on a cam swap
Hello too all. I need to know if I can use the cam out of a 1986 Honda XL600R and put it in a Honda XL350R both bikes have RFVC motors can any one give me info on this thanks.
ImageUploadedByThumper Talk1408192420.104755.jpgImageUploadedByThumper Talk1408192455.570125.jpg
there's stuff with diffrent part numbers but are the same thing too so for that you'd probably have to ask someone who's tried it or knows those engines very well
Different lift or different duration would make it have a different part number.
The part might fit physically but if the cam has a different cut it can greatly affect performance.
Sometimes for the better, most times for the worst.
I'm pretty sure from all my playing with XL600's that the whole engine looks very similar but all the parts are slightly smaller on the 350's.  If the rocker cover gasket #'s are different then I think the cams would be different. The older 250 and 500 cams would swap (1978-1981)  But I'm pretty sure that's a no go on the 350-600
