Can someone help me with this?
Hi
I´m a rookie in this area, have patient with me;-)
I wont that it goes smother over roots and rocks. I guess that it has to be faster in high speed?
I have a showa 48U with this setup in the basevalve:
Closes to the nut.
30,5-0,40
valve
32-0,22
3*32-0,1
32-0,35
2*32-0,1
32-0,35
10*32-0,1
30-0,1
29-0,1
28-0,1
27-0,1
26-0,1
25-0,1
24-0,1
23-0,1
22-0,1
21-0,1
19-0,1
18-0,1
17-0,1
16-0,1
15-0,1
14-0,1
20-3,15
4*12-0,2
You have shims stuck together , they will all be 0.1s , what bike is this ? Mid valve standard ? Oil amounts and spring weights ?
Hi
I´ve checked the stack to day. You mog was right, some of the shims was stuck. The bike is a Honda Crf250r 2011. The springs is one 4.4N/mm and 4.6N/mm in the other tube. Oil amount is 200 in inner and 300 in the outer. I´m greatful for the help I get.
So it locks like this.
BV
30*0,4
valve
24x32*0,1
30*0,1
29*0,1
28*0,1
27*0,1
26*0,1
25*0,1
24*0,1
23*0,1
22*0,1
21*0,1
19*0,1
18*0,1
17*0,1
16*0,1
15*0,1
14*0,2
4x12*,02
MV
(nut)
16*1,6
2x12*0,2
14*0,1
16*0,1
18*0,1
20*0,1
12*0,1
4x20*0,1
valve
4x20*0,1
18*0,1
16*0,1
12*0,1
11*0,3
14*0,2
11*0,3
2x16*0,3
For roots and rocks you need it much softer , you could remove one face shim off the mid for more float and a softer stack and say 7 face shims from the base and try that
Thanks mog
I´ll try it. I´m a little bit confused face shims for the MV is that the one´s under "valve" ?
(nut)
16*1,6
2x12*0,2
14*0,1
16*0,1
18*0,1
20*0,1
12*0,1
4x20*0,1
valve
4x20*0,1 Is this the comp?
18*0,1
16*0,1
12*0,1
11*0,3
14*0,2
11*0,3
2x16*0,3
The one´s I take away, shall I place them someware else in the stack?
Also remove some of the 24X 32 x 0.1 shims from the base valve. Mog said 7, which would be 17 total, seems like as good a starting point as any.
If that's not enough you could look at 2-staging the base valve, but these changes should be a big improvement.
Edited by Kyle Tarry
Thanks for the advise.
I´ve now removed 6 shims from BV and 1 from MV.
200cc in the inner tube and 300cc in the outer, 5w oil.
I tested yesterday  on a sandy track with deep whoppis and felt a big diffrens.  The fork did not bottoming, but felt a bit too soft. I have comp on 8click, but i want to test on the rocks before  do any more changes.
I´ll test the changes on saturday on a very stoning track.
The 2-stages BV sound intresting.
If its a bit soft in sand it may be still too stiff for rocks , sand requires a much stiffer setup
Correct mog, it was a little bit better but still felt stiff. It felt like the fork worked low. I'm Wondering If the HS in BV can help, what do you think? Or and one else; -)
Any way, it was a Great ride:-)
Did it bottom , did you try stiffer and softer with the adjuster ? Was it the best it's been so far ?
No, it didn´t bottom. It was a great diffrens to the better.
But it still feel a bit stiff , when the speed i low. I have 8 click out on comp and 12 click out on rebound.
I hop that I get time to test more some evening this week. I wont the fork too stay against wopps and swallow the sharp rocks, roots mm is 2-stage stack someting that is required then?
First I will say thanks for all tips and help, it´s great:-)
Now I have been testing a few times and it feels god when I have the speed but when the speed drops ( I get tierd) it feel a bit harsch. Eny one know a www adress there I can see what spring rate I suppose to use?
