Av gas vs vp
Well, what engine work has been done to benefit from more than pump gas? And what grade of av gas, pump is only 89-93, av gas is around 75-130 for range of grades.
100ll is good because it's more stable and no ethanol. Also can be easy to get depending on where you live. With a 2 stoke you can probably run a wider squish without detonation due to the lead.
Vp makes different fuels so depending on what you run some may be better than 100ll. The oxygenated fuels do offer an advantage but at a high cost and more care.
I run 100ll just to get ethanol free fuel and it's easy to get. Co doesn't have ethanol free pump fuel.
Well so far so good, predictably drags ass on low end, mid could be better, but top end will part ur hair! Idle's fine, but takes a bit to bring it to life. Already ran 5gallons through it, but Rpm's got to be higher than what should be to get into pb. Jetting? I ride mostly trail n some track @ 4,500'.
