08 te610
Solid bikes!! Only things you need to check are the timing chain (tensioner shouldn't be more than 8-9 clicks) and clutch spring cup washers go fast! Need to replace w/ Indy's ones. You can find him on ADVrider 610 owners thread. Other than that, great bikes! Had an 09 and it did 6k-7k trouble free miles. A JD tuner helps the FI (08-09) bikes run a bit better. A bit lean without it.
  • Like 2
7500 flawless miles on my 09. Did the JD Tuner and the power up and the bike runs clean and strong.
