kx250f high idle
You meant 'Choke' and not 'shock', correct?
Fast engine idle on 'choke' is normal.
When the choke is pressed in and the engine warm/hot, rpm should be about 1,850
You own a race bike, not a gentle play bike. It is not designed to be ridden slowly.
You will want to locate a service manual from a dealer and study it. You may need to adjust the fuel screw and idle speed iof the idle is not right.
