Rekluse EXP spring set up
I just installed the heavy wedges in my Core EXP on my 250. I'm running 3 blue and 3 red springs in the clutch and the ring. I still find it does not hit hard enough or engage early enough. I'm also running a hydraulic clutch which might be a problem. I have shimmed the arm on the Magura to extend the rod further as suggested by a Rekluse tech. What spring set up will engage quicker? 6 blue or 6 red?
I ran a EXP 2 ring that came with heavy wedges stock and I just used the springs that came installed. It hooked up just above idel and lifting the front wheel was no problem. That system relied on cable tention for setup though.
What shape are your clutchplated in?
