maintenance
Hey guys i have a 2010 kx250f and i was just wondering what all maintenance i need to do to it besides oil changes and oil filters and cleaning the air filter. i mostly ride trails with it and i am not that much of a aggressive rider. Thanks
Grease every bearing and every electrical connector...
Depending on the type of terrain ie lots of river crossings, mud etc you need to strip and re grease the suspension linkages and the swing arm bearings, fork oil should be changed and valve clearances checked, strip kick start and clean and re grease, spoke tension must be checked, brake pad wear, brake fluid levels need checking, steering bearing regrease
