2009 450 sxf oil over fill
I just did my first oil change on my sxf and I couldn't get the oil screen off so I thought I would worry about it next oil change I put just about 1.5 quarts in it and now it seems like it is running a bit sluggish, I also switched to 20w-50 oil, would it be the amount of oil or the different oil booging it down, and am I hurting it because I have to much oil in it?
IMO ...both are not helpful. Overfill is worse.
Loosen the drain plug and set to the right the level.
10/40 is the way to go.
You can also dump it on its side with the filler cap off to drain a little but its hard not to make a mess
