2010 crf transmission still engages when clutch is held
As I said in the header, my bike even when my hold my clutch in the bike creeps forward. I thought maybe my transmission fluid was dirty or something and realized it had a bit if water in it. I changed oil ran it for 5 minutes and changed it again but it is still doing it. Any clues?
Clutch basket arms are grooved and catching plate tangs so it won't release. Likely just time for some new parts, but disassemble and inspect it before buying anything.
The basket may be grooved and that will causse the clutch to drag.  Water will sometimes cause the fiber plates to swell so badly that the clutch will not engage. But that should go away after an oil change and some time. Like Eddie said you need to take it apart and figure out if the basket is grooved and, more importantly, where the water came from. When you get it apart mic the fiber plates to check the thickness. Good luck.
