1996 KDX 200 wont start!
I have a 96 KDX 200. Had new topend and reeds put in about 10 hours ago. I took is down the road really easy 1 time and ran perfect. Coming back I got on it a little but never full throttle in about 4th gear. All of the sudden I heard a real loud knocking noise. I let it sit there and try to idle but then it just quite. I tried kicking it but it was really rough. I pulled the spark plug out and kicked it about 20 times and all seemed normal. Put the plug back in and it was still really rough. It will try to crank but then quite all of the sudden. Any help would be appreciated!
Sorry to say but you should pull the cylinder back off and inspect it, if all looks good there measure the crank for correct bearing clearance and inspect the bearings for any damage
