Help setting timing on 07
Ive been struggling with a starting problem on my 07 250r, valves are new and in spec, for whatever reason I seem to think its a timing issue.  When setting the timing, I line up the punch mark with the arrow on the RH side of the bike then try to align the cut in the threads between the two hash marks on the LH side (at the magneto) and cant get them to both line up at the same.  Im assuming that they should right?  Should the cut in the threads be in between the two marks or just on one.  Is there a way to have both LH and RH marks lined up together?  Any help is appreciated thanks.
