Yz85 hydraulic clutch?
Hello well I just bought a yz85 and I have recently road a ktm85sx and loved the hydraulic clutch over the Cable clutch on the yz but is there a kit or Something that I can install on my yz for a hydraulic clutch? If it's even possible to convert a cable to hydraulic clutch cause it's a lot smoother and I can use 1 finger Easier on the hydraulic. Cheers!
Trust me it's not worth the extra couple hundred. The clutch lever on my 125 is as smooth as butter and I don't need a silly hydraulic clutch. Try and move the whole clutch assembly closer to the center of the bar so your fingers are at the end of the shifter. Then try it. if it don't make it better. Lube the lines.
Ok well I ended up finding dirt and grit in the part where the cable and the lever are connected. I cleaned it all out and replaced the levers with shorty's so it is much Easyer thanks also put some lube on the cables that helped too. Thanks for the help
