Cylinder head exhaust mount bolts
I need to replace the two bolts to mount my exhaust. Does the removal simply involve backing them off with vice grips? Since I'm replacing them, I suppose it's not a concern to have to clamp onto the bolt threads. For installing new bolts, just thread nuts half way down bolts and turn on the attached nuts? Is there anything I should apply to the bolts for easier threading into the cylinder?
Spray the threads many times over a few days with the above or Kroil or other stuff or.... many different kinds! If you break the stud off, you just caused a lot more problems. Personally I don't see a problem with vice grips but I wouldn't start out with them, that is for sure.
Edited by DR.billZ
