2009 Kx250F building internal pressure
The valve cover (half moons) and the clutch cover started leaking at the same time. Thinking the vent hose was clogged, I pulled the crankcase vent hose off to find out it's clear. tried to shoot air in the inlet the hose goes onto and can't blow into it with the oil fill cap off. Should I be able to?  Is there another vent inside the flywheel cover also? Help!!!! Anything else to relieve internal pressure that I could try, let me know. Thanks!!!
If you start the bike can you feel the air blowing out the vent hose ?
