89 RM 125 swap out
If I swap the 89 exhaust from the exhaust port through the silencer with something from 01-06... will the engine run like crap? Other than the obvious pipe routing, anything else I should worry about? Since I swapped out the 89 subframe with a subframe from 04, the silencer/expansion chamber pipe won't fit.
