KLX250 float level height
2009 KLX250 SF; Anybody know where the float height is supposed to be when using a clear tube off the drain? Does it sit right at the split line of the bowl or over/under a certain amount? Should it be checked on the bike or level on the bench? On the bike it sits at an angle so I guess just use the the height in the middle as the average? Selling the bike so dont really want to purchase a manual, just trying to get it starting better and running right for the next guy
Edited by zx6rrider
Thanks I will try that method. I've always used a clear tube off the drain to see the level in relation to the carb split line but couldn't remember if it was supposed to be even or a little above or below. Anybody know the official height for the klx, Ive seen 18mm and 14mm
I read it 3 times now so maybe I'm missing something....it says 15 mm as an example but I"m assuming that every bike has different specs? I didnt see anywhere that that specified KLX250
