kfx400 Powerloss?
i got a kfx400 couple of weeks ago and its loosing power.
After changing gears it used to pull when giving gas and now its slow when giving gas after changing gears.
no idea why . you guys think i should change the oil? Clean out the carb? any opinions would help.
You should always change your oil often anyways.
Clean your carb, put a new plug in it and run a compression check. The engine is probably just getting wore out and in need of a rebuild.
Edited by leafsrule16
