Husky te 610
Does this help?
Removal of smog stuff, compliments of speedzilla.
1. Disconnect the carb vent lines/fuel lines and remove the tank and the     headlight unit.
   2. Take a look at what goes where... where the hoses go.
   3. Remove the manifold that is zip tied by the ignition switch
   4. Remove the small cannister attached to the lower triple
   5. Disconnect the hoses that connect to the pink carb vent lines and reroute the vent hoses
   6. Disconnect the hose from the nipple on the intake side of the head, near the carb boot and plug it up with an automotive vacuum plug
   7. Remove the large cannister and attached hoses.
   8. Install one of those little aluminum no spill fuel vent fittings to the top fuel vent nipple on the tank.
   9. Reinstall the tank and headlight and you're good to go. Don't forget to plug the nipple on the side of the head. It is a vacuum line and will suck air otherwise.
Edited by gots_a_sol
