Cr125 forks?
Hello everyone, so i cant figure out why my bars look bent. In the picture you can see the fork bleeder screws are in different spots and i dont know how to fix it. I even tried a pair of new bars on and it looks the same so the bars arnt bent. Any suggestions?
It's most likely the rubber bushings in the top clamp. Replace them and see if that does it.
If you are talking about the bleeder screws,just loosen the triple clamp bolts up a little bit (top/bottom), enough to twist the tubes and bleeders to your desired spot. Then torque the bolts back to spec. The handlebars usually straighten after loosening and then torque to spec the clamp nuts in the underside of the top clamp.
I changed the rubber bushings on the top and bottom so ill try twisting the forks, do you know what tge torque is for the triple clamps top and bottom are?
