xr100 idle issue
well my 2000 xr100 has a issue idling, when your on the throttle it is breaking up slightly off the start but clears and runs great once the rpms climb, then when you come to a stop the idle is really low and choppy. it also likes to die when you come to an abrupt stop. I've cleaned the carb plenty of time. soaked every jet, cleaned them with wire, and can see daylight through them. fuel screw is brand new, I've tried richen and leaning it up, that makes no difference. the plug is new. sprayed brake clean on the insulator boot and doesn't have air leaks, I'm stumped on this one?!
I would replace the pilot jet as it may be opened up a bit if you used wire on it. Be sure you have the oring in the fuel screw and have the washer and spring in the correct order.
Also adjust the valves.
