Trip to CO, rejet FCR?
Gonna spend a week or more on trails in the CO mountains, mid-late Sep!  Current setup is:
440 kit
Yosh full exhaust
Hot Cams
FCR with following (kinda standard) settings for sea level.
slide needle: OCEMN, 3rd clip from top
Main jet: 160
slow/pilot jet: 42
slow/pilor air jet: 100
main air jet: 200
start/choke jet: 72
Bike currently runs spot-on from sea level up to 4k' (never had it above that).
I'm not concerned about absolutely performance, just don't want stuttering/plugfouling/hardstarting/missing while in the CO mountains (6-10k?).
Recommended jetting changes? Should I bother?
From personal experience, I would. I'm jetted for sea level. When I went to deals gap last year and rode into the mountains after about 8k 5th gear became all but unusable. Granted I'm geared for highway cruising, but I would suggest to do it. I couldn't imagine what a sea level jetted bike would run like at the top of copper mountain or in Vale.
I've had mine on Deals, no problem. FYI, the highest peak in TN and NC is around 6,500'. :)
But yea, if I can get a ballpark of what to do, I'll rejet.
Here Eddie recommends 142 main jet for similar circumstance :
http://www.thumpertalk.com/topic/693214-drz400e-high-altitude-jetting-recommendation/
There was a time when I could have the FCR out/in in 45 min. That was  a few years ago. :)
Edited by aeronaut
I just ordered a handful of main jets, and will try 142 first. Hope they're not too difficult to change in the field if needed!!
6 to 10 K...with 3x3 , open pipe,BB....I would suggest
145 main jet
OCEMR Needle, clip 3
45 pilot jet
1.75 turns fuel screw
For your current riding elevation I would use
155 main jet
OCEMP needle, clip 3
45 pilot jet
2. turns fuel acrew
With an Fcr main jet and needle can be swapped out with the carb installed....
MJ= Use a 6mm socket or jet tool via the 17 mm cap on the bottom of the bowl....http://www.jetsrus.com/individual_parts/mp_08_0023.html
Needle= via top of carb
Edited by Craig-o
