Honda 2013 Honda TRX250x Fuel screw
Im getting some popping on decel. I have an FMF Powercore 4 addon along with TwinAir filter.
Its my understanding a possible cause is running too lean, and one solution is to richen mixture with the Fuel Screw.
However, the screw is tamperproof on this model. Any suggestions?
Pull carb, drill small hole in brass plug covering fuel screw, thread drywall screw into hole you just drilled, grab screw with vise grips and pull plug, if you have the weird d looking fuel screw, you can get it out with a small flat tip screw drive then cut a slot or replace with after market adjustable.
