xr650l need help with jetting
mY setup im running is stage 1 hot cam K & N filter d snorkeled d smogged everything else is stock xcept I did Dave's mods to the carb the problem I'm having is it seems to run fine but when I let off the gas it has a slight backfiring when its in gear And I'm slowing down tried messing with the air fuel screw made no difference The Jets I'm running is 55 pilot 160 main
check the bolts I found an air leak under the top part of the carb by the diaphragm is going to try that hopefully that helps
