te 510 jammed up
I was out on my Te 510 at the weekend 06 model. It started to mid fire then got louder in the engine so I stopped the bike. Tried to move the kick start and was jammed. Electric start would not start it either. Since taking the engine out of the bike I have been able to move the kicksstart easily with my hand but now has jammed up again. Before I go into the cylinder any advice?
Quickest way to find out your problem .
Remove spark plug.
Remove clutch cover.
Remove clutch.
27mm socket on primary gear nut try to turn it over, if it turns over what seems to be fine, then its probably in trans.
Look for shrapnel in the cases under the clutch area.  like gear teeth?
  • Like 2
