KYB 46 mm shock spring on 50 mm Showa shock. Will it fit?
Bought a Showa suspension (from 07 CRF250) for my 07 CR125, modified by Factory Connection, but the rear spring was repainted and there is no receipt available to determine the spring rate, it'll be here in a month, so I can't test it also. I have a stock 4.7 kg KYB spring off a 46 mm KYB stock shock, will it fit 50 mm Showa shock if needed?
No it won't;
KYB 46mm: spring diameter (59/62)mm
KYB 50mm: spring diameter (64/66)mm
Showa 50mm: spring diameter (64/66)mm
The spring I used on my 2013 KX450F with a 50mm KYB would not fit on my 2015 with a 50mm Showa. The spring on my KYB was 64/64 and the Showa was 64/67. They were both Factory Connection springs.
Edited by mx317
