Has this serial number been tampered with?
Guys,
This is a 2003 DRZ400E,
Does this stamping look suspiscious? The "4200" is at a slight angle and the gap between the last "0" of the "4200" and the following "1" looks too big.  Has this been tampered with?
Edited by segge
Guys,
Not to me....all the numbers are made with the same stamp, font, etc...
So, you are asking for a critique of your work?  :smirk:  (couldn't resist the comment, I have no opinion on the actual question)
  • Like 2
It looks legit but... does it match the title or MSO?
Often, serial numbers  have been imprinted using different typeface fonts to make re-stamping more difficult to match, E, a larger set of stamps must be owned
I'm in Senegal, Bought the bike from a guy who left the country. I took the bike in for inspection and they say there is a problem with the number
Edited by segge
Looks suspect for sure,  the 2 0's in the middle are lower then the rest,  you can kinda see marks on the metal,  i would not buy that bike.
First digit - Country code
Japan (J)
Second digit - Manufacturer
Suzuki (S)
Third digit - Identifier
Motorcycle (1 or A)
Fourth digit - Vehicle category
Business model or commuter ( B)WRONG
Fifth digit - Engine Displacement
Data here is Suzuki specific, haven't found info for other brands.
A=49cc and less
B=50-69cc
C=70-79cc
D=80-89cc
E=90-99cc
F=100-124cc
G=125-149cc
H=150-199cc
J=200-249cc
K=250-399cc WRONG SHOULD BE A LETTER NOT NUMBER IN THIS POSITION
Sixth digit - Engine Type
1=2 stroke single WRONG SHOULD BE A NUMBER 4 IN THIS POSITION
Seventh digit
Design sequence or model version first version uses 1 then second version uses 2 etc... the tenth version would then be identified by the letter A then B etc..
Eigth digit
First version uses 1 then second version uses 2 etc... the tenth version would then be identified by the letter A then B etc...Ninth digit - Check digit
The ninth vehicle identification number digit is a VIN accuracy check digit, verifying the previous VIN numbers. This is how the check digit works
STEP 1
Assign to each number in the VIN its actual mathematical value and assign to each letter the value specified for it in the following chart:
ASSIGNED VALUES:
A=1 G=7 P=7 X=7
B=2 H=8 R=9 Y=8
C=3 J=1 S=2 Z=9
D=4 K=2 T=3
E=5 M=3 U=4
F=6 N=4 V=5
STEP 2
Multiply the assigned value for each character in the VIN by the position weight factor specified in the following chart:
VIN POSITION AND WEIGHT FACTOR:
1st = 8 10th = 9
2nd = 7 11th = 8
3rd = 6 12th = 7
4th = 5 13th = 6
5th = 4 14th = 5
6th = 3 15th = 4
7th = 2 16th = 3
8th = 10 17th = 2
9th = check digit
STEP 3
Add the products from steps 1 and 2 and divide the total by 11.
STEP 4
The numerical remainder is the check digit which would appear in the 9th position in the VIN. If the remainder is 10, then the letter "X" is used for the check digit.
WRONG cHECK NUMBER
  • Like 6
Japan (J)
Suzuki (S)
Motorcycle (1 or A)
Business model or commuter ( B) WRONG
A=49cc and less
B=50-69cc
C=70-79cc
D=80-89cc
E=90-99cc
F=100-124cc
G=125-149cc
H=150-199cc
J=200-249cc
Seventh digit
Eigth digit
STEP 1
ASSIGNED VALUES:
A=1 G=7 P=7 X=7
B=2 H=8 R=9 Y=8
C=3 J=1 S=2 Z=9
D=4 K=2 T=3
E=5 M=3 U=4
F=6 N=4 V=5
STEP 2
1st = 8 10th = 9
2nd = 7 11th = 8
3rd = 6 12th = 7
4th = 5 13th = 6
5th = 4 14th = 5
6th = 3 15th = 4
7th = 2 16th = 3
8th = 10 17th = 2
9th = check digit
STEP 3
STEP 4
WRONG cHECK NUMBER
Is this in FACTS? VERY USEFUL.
All that above said..
Republic of Senegal, a country in West Africa may have it's own procedures for marking (changing) a VIN after a theft recovery, importation, insurance total, custom build? ect.
​I have no personal experience or expert knowledge of how Senegal handles such things.
